Survey after a simulive
Can you have a survey pop up after a simulive? Do you have to have it roll to live or not to do this?
Yes you can @cindy.1 this is just a setting in your survey. If you go to the configuration of your survey you can chose if you want it to pop up at the end.
If you record the webinar before hand in ON24 as well (as a event with no audience) you would also have the option to highlight it or center it via the engagement tools you have as a producer.
